1 - 5 of 5 Posts
Retired
[email protected] is saying it cant send in results. Recently I switched to vista RC1, does that have anything to do with it? Should I turn off the Windows Firewall? Thanks for your help, pic of the error below.<br><a href="http://assets.overclock.net.s3.amazonaws.com/b/b6/b6f1d31d_vbattach33054.jpeg"><img alt="LL" src="http://cdn.overclock.net/b/b6/525x525px-LL-b6f1d31d_vbattach33054.jpeg" style="width:525px;height:267px;"></a>
Most likely that collection server is currently down, especially since it appears that you successfully downloaded a new WU. If that's the case, it will periodically try to submit the completed work, and it will go once the server is back up. This sometimes takes several days, but rest assured that the WU will count.
Retired
Ok, thanks for the info, I wont worry about it then. <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Retired
Discussion Starter #5
Well, 12 hours or so later it still hadnt sent went ahead and installed XP, moved the files over, and it sent on the first time. Guess it was something wrong with Vista RC1 after all. Anyways, just means Ill have to re-install RC1, evidently I didnt do the dual boot correctly the first time and I can boot to it.
1 - 5 of 5 Posts
