Have a 980x with Rampage III Extreme motherboard. I have it 33 hours prime95 small fft stable. Also did it for an additional 25 hours. Now trying to stabilize the memory.*
Have three two gb Super Talent 2000 7-7-7-21 memory.*
Settings in the bios are:
Cpu ratio: 31
BCLK: 142
dram freq: 1992MHz
UCLK freq: 3986mhz
Qpi link: 6833MT/s
CPU Voltage: 1.26875
Cpu ppl: 1.815
qpi core voltage: 1.31250
Dram bus voltage: 1.64300
Top end XMP lists the memory can do
Freq: 1000
cas#: 7
ras to cas: 7
Ras precharge: 7
Tras: 21
2T
Stays stable in prime custom with 5096 megs set for 8 hours. *Have the memory at 8-8-8-25 so a bit loose.*
Made the following changes
CPU Voltage: 1.290 from * 1.26875
qpi core voltage: 1.33125 from *1.31250
Dram bus voltage: 1.65625 from *1.64300
Stays stable in prime for 12 hours but still crashes. What am i doing wrong? *Any advice would be appreciated.*
Thanks
JR
Cpu ratio: 31
BCLK: 142
dram freq: 1992MHz
UCLK freq: 3986mhz
Qpi link: 6833MT/s
Cpu ppl: 1.815
Freq: 1000
cas#: 7
ras to cas: 7
Ras precharge: 7
Tras: 21
2T
Thanks
JR
