1 - 9 of 9 Posts
you sure its for the correct model? also run as admin and if that fails try safe mode install
Originally Posted by L3gacy
run the package as admin under windows vista compatability
Just tried that, still the same error.
It's for Intel's Mobile 4 and HD series
Would uninstalling and reinstalling the drivers work?
also if the downloaded package doesnt work download for windows xp and run in compatability mode under admin, this has worked for many people I have helped,
what operating system is the package for anyways?
Discussion Starter · #6 ·
Download the XP drivers?
It's for Win7 x64 but Intel's download center shows them as being for Vista as well.
Discussion Starter · #8 ·
try the windows xp x64 driver and run under windows xp sp3 compat as admin
(sounds retarted but thats how I fixed my old motherboard driver issue with the intel graphics)
When I run it I get a message saying that my computer has newer driver blah blah blah do you wish to overwrite them? Since the XP drivers are older there isn't really any point I guess to try since I'm trying to upgrade them. Should I just try to completely uninstall the drivers and allow windows to grab the newest ones via WinUpdate?
Discussion Starter · #9 ·
Uninstalled the driver and ran the installer. Worked perfectly, another incident that can be chalked up under the "Wonderful World of Windows".
1 - 9 of 9 Posts
