1 - 2 of 2 Posts
I know you guys like to fiddle with capacitors so I thought I would share yesterday's experience and offer a teaching moment.
I rebuilt an old Wavetek Function generator recently. Mostly, I replaced the electrolytics. After powering it up and seeing it did not work, I shut it down and put it away for another day.
Yesterday was another day...
I noticed that a few of the electrolytics were not replaced, so I replaced them. I also noticed that a couple of fuses were blown--replaced them.
Then I flipped the switch with my o-scope monitoring the output. Hmmm, I get a sine wave with a lot of 60 Hz interference---maybe the pwr supply has a problem...I lean back in my lab chair and...POW-POP-SMOKE-ELECTROLYTE SPLATTERED ALL OVER THE PC BOARD.
I hit the switch and fanned away the smoke.
Further study indicated that I had installed a 1000uF 35V cap backwards (wrong polarity).
I replaced the cap using the proper polarity, hit the switch and quickly retreated a couple of feet and waited. No POP, no SMOKE.
I got enough courage to move closer and check the output with the o-scope.
Yihaa!! Sine wave looked good (2nd and 3rd harmonic down 40db and no 60Hz interference).
Lesson: POLARITY MATTERS
(Of course, I knew this, but on that one cap, I was careless).
Yes.... polarity matters.
How do you replace electrolytic fluid?
1 - 2 of 2 Posts
