I'm about to buy a new HSF for my video card because the stock on is way too loud and I figured why not buy some case fans while I'm at it? My ram and the heat sinks on the top right corner of my motherboard are very hot. I have enough room to fit a 120mm or 80mm fan in the front drive bay and a 80mm fan on the side grating. How should I set this up for the best cooling and airflow? Here's a diagram of my case:
