1 - 6 of 6 Posts
Yes
I have a question about fans. I'm running a very old ATX case with only 2 fans in front and 1 in the back (not including the powersupply). Since I have two Drive slots open, what I'm planning to do is fill that area with 2 fans and a piece of mesh in the front. My question is, what's the best fan to use for the job? I need something high powered since there's very little airflow due to the extremely wimpy fans that came with the case.<br />
<br />
Thanks in advanced,<br />
Fallen
How about just replace the stock fans with higher flow ones, not suoer high flow like the delta fans, because they are soo loud its unbearable. Just replace them with say these!<br />
<br />
80mm: <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811999120" target="_blank">http://www.newegg.com/Product/Produc...82E16811999120</a><br />
120mm: <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811999122" target="_blank">http://www.newegg.com/Product/Produc...82E16811999122</a><br />
or <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835220015" target="_blank">http://www.newegg.com/Product/Produc...82E16835220015</a><br />
<br />
PCI Slot: <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835117010" target="_blank">http://www.newegg.com/Product/Produc...82E16835117010</a>
These are the fans that I use they are a little loud, but have great air pressure and air flow....<a href="http://www.svc.com/kd1212pmb1-86.html" target="_blank">http://www.svc.com/kd1212pmb1-86.html</a><br>
Sunon 120mm Ball Bearing Fan w/ 4pin 108CFM 42dBA
Get a Thermaltake Thunderblade, moves a decent amount of air very quietly. [email protected] 21dcb. Comes in red, green, or blue <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br><a href="http://www.svc.com/a1926-14.html" target="_blank">http://www.svc.com/a1926-14.html</a>
Do you have the space for a 120?<br><br><a href="http://img137.imageshack.us/my.php?image=crysalis2yl6.jpg" target="_blank"><img alt="" src="http://img137.imageshack.us/img137/6841/crysalis2yl6.th.jpg" style="border:0px solid;"></a><br><br>
This helped alot, though it takes 3 bays!
Yes
Discussion Starter #6
thanks for the input <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"> ill look into the fans.<br>
i have 2 bays im planning to useup for the fans. im planning to fill the 2 bays with 2 fans and a mesh. its about in the middle of the tower. What im planning is very simular to what you posted,syrillian, cept im 1 bay shy.<br><br>
This is the case i have, but without the plexiglass and fans on the side.<br><img alt="" src="http://images10.newegg.com/NeweggImage/productimage/11-156-019-32.JPG" style="border:0px solid;">
1 - 6 of 6 Posts
