I would say that you should get something like the Xigmatek s1283 because it's a smaller unit. It may be smaller, but it's an HDT cooler (Heatpipe Direct Touch, or something). I say get the Dark Knight version because it includes a good fan. Here are two different ones at Newegg: the s1283V and the s1283. I think the difference with the "V" version is the fan that it comes with has a "Long Life Bearing". So, perhaps it means "Value".
Anyway, the s1283V is $39.99 before shipping, and the s1283 is $44.99 before shipping. Except the s1283 is not in stock right now. So, I guess that if you go with this one, then you're stuck with the better option. hehe
P.S. This is the CPU cooler that's being affectionately called the "Xiggy".
