Do they have clearance issues with fan controllers?
Do they have issues with airflow?
I got Delta fans so fan controller is needed.Originally Posted by VeryChilled;13058698
well that would depend on what case you want, however with my setup ive never noticed a decrease in airflow at all, ive also never thought about it as the effects should be extremely neglegable. Im a little curious now and will try it but I doubt anything will happen.
I think convenience is a much bigger factor in deciding whether you want a door or not, they can be a bit irritating if you use your fan controllers alot or if your constantly changing DVDs.
The rig I'm building for this has a vanilla 480 so doors are a hazard.Originally Posted by VeryChilled;13058988
wow im actually shocked, there seems to be a 3.1 degree difference between door open and closed
Door: I can go ghetto with 5.25 bays.Originally Posted by VeryChilled;13059068
what case are you looking at?
personnally i would go no door, not because of temps though.
