1 - 14 of 14 Posts
Just hangin' out
Does anyone have a source for fan wire?
Not hookup wire, the insulation is too thick.
I need the 24AWG three conductor (black, red, yellow) wiring that nearly all 12V non-PWM fans use.
I would like to get a spool or roll of 50 feet.
Just hangin' out
Thanks.
But, I did not see red or yellow?
Can anyone verify the fan wire is UL 1061?
I’m not sure the color matters, as long as it’s connected right.
I’m just leaning to make cables myself so I’m not sure
Color does not matter as long as the gauge is correct, it does help make sure you hook them up in the right places, but if your careful you can use all one color wire to wire anything up.
That was a fun learn for me. You sleeving and building custom length harnesses for your PSU?
I'm going to likely start with making my own fan extension cables and then likely try the PSU depending on how well I do with the fans. Waiting for MDPC-X to have it's black Friday sale and pick up as much stuff as I can.
Just hangin' out
Discussion Starter #8 (Edited)
Color does kind of matter, as I am wrapping several sets of wires in Techflex before I cut to final length and apply the terminals. I need to be sure I have the correct +12V, Gnd, and RPM wires. I could mark each conductor with tape or wire numbers or something, but I believe is easier just to have the correct colors.
Already done that, now I am making a radiator fan harness for eight fans. Radiator is external, BTW.
Also, 22AWG is just too big size to make daisy chains. 24AWG is hard enough to get a good crimp with two conductors.
9 Cans of Ravioli
Just hangin' out
Discussion Starter #10
*edit* I'm an idiot, I thought you were guessing at the gauge in the OP. never mind me
Would it be less racist if I chose only one color?
The PSU cables still make me nervous, I took my EVAGA harnesses and replicated them but only 8" long instead of the 4' ones they send with the PSU, then I can just make one-to-one extensions and I don't have a ton of wire in the case.
I've looked at MDPC-X before I really like how vibrant their colors are but I still have quite a bit Teleios sleeving on hand and no plans to redo my color scheme in the near furture.
Yea if your going to pre-wrap them with something I can see wanting colored wire, though strictly speaking color doesn't matter, electrical current doesn't care what color the wire is. I have marked wires before with numbers from my electricians label book (don't tell my boss) but those books can be kinda expensive, but you can find them at Lowes or Home Depot.
I had a hard enough time with 22AWG getting a good crimp, didn't feel like buying another set of dies for my crimper that would do a smaller gauge.
Just hangin' out
Discussion Starter #13
<SNIP>electrical current doesn't care what color the wire is.<SNIP>
Been doing electrical work going on 35 years, you do not have to tell me...
I pay about $7 for one.
I have three crimp tools, all have multiple gauge die sets.
1 - 14 of 14 Posts
