1 - 20 of 22 Posts
Alright, so I need to fit one of my computers under my desk, and my pc-B10 wont fit,
So I need a new one.
I know of the A05Nb or whatever that short stout case is from Lian Li for 89.99 at newegg, which I will probably get, but I was wondering if there are any other cases that size.
Short and long I should say, no higher than the a05. That will just fit where I need it.
Thought I'd leave you a photo to help with your decision
I love it, the best case i've had, quiet, amazing cable management, small but not too small, perfectly built for a h50, and sleek looking, worth the premium
Discussion Starter #11
Oh I know its a pretty good case.
Its just I cant find them for a good price here in the USA. Im not paying 120 bucks for it... lol but I may.
Man with Fans
AeroCool PGS-Q Qs200.
Inexpensive and functional.
And craploads of airflow.
Will fit a 120mm cooler; the Hyper 212+ specifically. But if you use the H212+ you won't be able to use the upper side fan, and you'll have to reduce the size of the lower side fan to 92 or 80mm instead of 120. Don't worry, the fan grills have fittings for all three sizes.
Two 120/92/80 slots on front, two 120/92/80 slots on side, one 120/92/80 slot on rear.
Discussion Starter #17
Well I just said screw it..
using my pc-b10, its a 270 dollar case, not just gonna let it sit unused.
bought some other stuff instead of a new case.
1 - 20 of 22 Posts
