Case for my build?
350 Views 9 Replies 8 Participants Last post by  Andru
hi,
due to a recent **** up with shipping, i decided to cancel my order of the coolermaster HAF and since its out of stock everywhere, im looking to get a new case. any suggestions on something comparable to this?
1 - 10 of 10 Posts
I love my CM590. Much cheaper than the HAF and does everything you need it to do. My sig rig is in one and it works beautifully. Great modder too...
cm 690 if you're sticking with Coolermaster.
get a half decent case and modd it like i did! check out my project!!
thats my plan
oh and i dont have any preferences... just 175 CND
I woudlnt get a cosmos if your comparing it to the HAF. Compared to the HAF (and most good air cooling cases for that matter) the cosmos S has HORRIBLE cooling. CM sniper, Antec 1200, Antec 900 TWO, antec 900, cm stacker 830 and CM 690 would be comparable to the haf when it comes to cooling and space.
Antec 1200 is pretty comparable with the HAF.
Actually from what I've heard, the HAF and Cosmos S are pretty much the same in terms of cooling. For water cooling I'd go with the Cosmos S but if you're just going air the Coolermaster 690 is a great case.
1 - 10 of 10 Posts
