1 - 14 of 14 Posts
What is your budget? I'd recommend something from case labs if you can afford it
Yeah, case labs M8 could be good for you. But why RX, shouldnt you use something with more fins if you're going to have P/P with 38mm fans?
My phan is to put my rx360 and all of its 38mm fans in a second case that sits behind my case. It will store the second rad and both pumps when I'm done. I basically am recycling an old compaq mini tower , dremmel ftw
The brand spanking new nzxt switch 810 seems like one heck of an water coolers case. Supports thick 360 rads in the top with push/pull right out of the box. Even the price is quite reasonable. You should definitely check it out
I think the nzxt switch has 90mm space inside for rad, so couldnt even do push with 38mm fans... Shinobi xl could have it in front but you'd lose hdd and odd bays, dunno about the clearance on top... I still think case labs is your best bet.
Now that's nice o_O
Seams to fit what I need
But would 38mm fans fit push pull? :/
And wonder when it comes to Australia lol
Originally Posted by Liighthead View Post
Now that's nice o_O
As I said in the above post, the nzxt switch 810 has 90mm of space for internal rad mounting (according to specs). The RX-series rad is 60mm and if you use 38mm fan the total thickness will be 98mm, which is too much. The fan mounts are meant for 140mm and 120mm fans, so when using 120mm fans the rad might be offset a little so you may be able use the 38mm fans without it hitting your mobo. Under the top cover you have some space which I believe is meant for 25mm fans, so you probably can't fit a 38mm fan there either, see This picture.
I just have to say it...
That is one hell of a case for the price point. I may not meet your initial goal, but everyone should really take notice of this case.
I wish the side panel was a little more symmetric, i would be considering replacing my HAF X
Discussion Starter · #13 ·
thanks for that
think i might wait for it to get to australia and get one.. and mmm might have to change fans :/?
will weigh it up once get the case.. either push pull 25mm fans... or one side of 38mm fans.. :)
thanks
true this..
and side panels can always be cut out
I don't think you can use the 38mm fans with the RX rad at all. Buy yourself some 120mm yate loons for the rad and use the 38mm fans as intake? Yates are great fans with even better price
1 - 14 of 14 Posts
