HI
I am planning to jump the threadripper wagon from my 4 years old 4770k system and has been doing some research for a multi propurse Workstation/Virtualization/Gaming Machine.
I would like to have some feedback regarding my build and if you see any problem with it. My goal is to reach at least a 4 Ghz Overclock so i would be fitting a LiqTech TR4 360 water cooler and a Case that can fit that cooler.
I has been looking these two options but would like to get other options also. Basically i am looking, a) can fit the liqtech radiator, b) has enough space for the components and good thermals, c) it is not massive like the Thermaltake X9.
1) Case: Phanteks - Enthoo Luxe Tempered Glass (Black) ATX Full Tower Case
2) Case: Corsair - 760T Black V2 ATX Full Tower Case
3) other?
Thanks a lot!
Pat
CPU: AMD - Threadripper 1950X 3.4GHz 16-Core Processor
Motherboard: Asus - ROG ZENITH EXTREME EATX TR4 Motherboard
Memory: G.Skill - Trident Z RGB 64GB (4 x 16GB) DDR4-3600 Memory
SSD: Samsung - 960 Pro 1TB M.2-2280 Solid State Drive
HDD: Western Digital - Red Pro 8TB 3.5" 7200RPM Internal Hard Drive x 2
ODD: Pioneer - BDR-211UBK Blu-Ray/DVD/CD Writer
Video: EVGA - GeForce GTX 1080 Ti 11GB FTW3 GAMING iCX Video Card
Power: Corsair - AX1200i 80+ Platinum Certified Fully-Modular ATX Power Supply
Cooling: Enermax - LiqTech TR4 360 102.2 CFM Liquid CPU Cooler
Cooling: Corsair - HD120 RGB 3-Pack w/Controller 54.4 CFM 120mm Fans
Cooling: Corsair - HD140 RGB 74.0 CFM 140mm Fan x 3
Edit: Removed SLI reference
3) other?
Thanks a lot!
Pat
