Hello all! I am in love with the Lian Li PC-TU 100, and I have been dreaming of building a high power gaming rig in one of these cases for a long time.
The plan for this PC is to be a compact, portable, high power gaming rig. However, out of the box, this case has many issues.
The case is designed to have 1x 120 mm case fan in the front of the case, and use an SFX power supply as an exhaust. The bottom of the case is designed to house 2x 2.5" HDD/SSDs, so there is no intake for the GPU. Also, out of the box, the case only supports up to a 60mm Heatsink for the CPU. Many members in the Lian Li PC TU100/200 Owners Club have reported issues with thermals, specifically in the GPU region, as well as an inability to efficiently cool overclocked CPUs.
A lot of the inspiration of this build comes from @UncalledForGabe's Lian Li TU100 Heavy Breather Case Mod. In his build, he managed to install x5 Case Fans, and custom sleeved PSU cables.
I am not anticipating painting the case like he did, but I do plan on trying to pack in as much airflow as possible. The goal for this systems is to be a fully overclockable air-cooled system.
One final thing to note, this project is going to take me several months to get put together. If you are interested in seeing my first major case mod succeed (or fail), stay tuned!
- Fully Air Cooled
- Overclockable CPU/GPU
- Side Panel Window
- Custom Sleeved Non-Modular Flex-ATX PSU
- RGB Case Lighting
Honestly, there is nothing special about the name. I am a big anime nerd, and all of my computers are named after some random anime character. The names are selected by either myself or my girlfriend, who is also a huge anime nerd.
That being said, when I picked the name for this, I literally googled "Short Anime Characters", and one of the results was Chiaki Nanami, from Dangan Ronpa, which happens to be one of my girlfriend's favorite Visual Novels and animes. It just so happens that Chiaki's title in the game is "Ultimate Gamer".
Even though it is super tacky, and the color scheme of this build is not necessarily appropriate in regards to matching the characters, it doesn't really matter to me. I am happy with the name, and the uncanny coincidence.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor (Purchased For $0.00)
CPU Cooler: be quiet! PURE ROCK SLIM CPU Cooler 120W ($20.00)
Motherboard: Asus Z170I PRO GAMING Mini ITX LGA1151 Motherboard (Purchased For $0.00)
Memory: Kingston FURY 16GB (2 x 8GB) DDR4-2400 Memory (Purchased For $79.00)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive (Purchased For $229.00)
Video Card: Sapphire Radeon R9 Nano 4GB Video Card (Purchased For $360.00)
Case: Lian-Li PC-TU100B Mini ITX Tower Case (Purchased For $0.00)
Power Supply: Athena Power 400W 80+ Bronze Certified Mini ITX Power Supply (Purchased For $45.00)
Case Fan: Noctua NF-A9x14 29.7 CFM 92mm Fan (Purchased For $0.00)
Case Fan: Noiseblocker NB-BlackSilent Fan PM-2 40mm x 20mm (Purchased For $14.95)
Case Fan: Fractal Design FD-FAN-SSR2-92 24.6 CFM 92mm Fan (Purchased For $0.00)
Case Fan: Fractal Design FD-FAN-SSR2-60 20.0 CFM 60mm Fan (Purchased For $0.00)
Case Fan: Fractal Design GP12-WT 52.3 CFM 120mm Fan (Purchased For $0.00)
Monitor: ViewSonic XG2401 23.6" 144Hz Monitor (Purchased For $239.99)
Keyboard: MK Disco RGB LED Backlit TKL Mechanical Keyboard (KBT Brown Switch) (Purchased For $100.00)
Mouse: Razer Mamba Tournament Edition Wired Laser Mouse (Purchased For $65.99)
Sound Card: Schiit Fulla 2 (Purchased For $99.99)
Headphones: Beyerdynamic DT 770 Pro 80 ohm Studio Headphones w/ Hard Case (Purchased For $160.00)
Other: Antlion Audio ModMic Attachable Boom Microphone - Noise Cancelling with Mute Switch (Purchased For $54.99)
Other: Razer Firefly - Cloth Gaming Mouse Mat (Purchased For $59.99)
Other: Phanteks PH-CB-Y4P 4.3" 4 Pin PWM- Y Splitter Fan Cable (Purchased For $5.98)
Other: Philmore 3.5mm Gold Plated Stereo Snap-In Panel Mount Phone Jack (Purchased For $8.95)
Other: Ugreen Gold Plated 3.5mm 1/8" Male to 6.35mm 1/4" Male TRS Stereo Audio Cable (3ft) (Purchased For $8.99)
Other: Grifiti Chiton Fat 14 6" x 15" Neoprene Keyboard Sleeve (Purchased For $14.98)
Other: Zeskit 4', 3.5mm, Braided Nylon Stereo Audio Cable (Male to Male) (Purchased For $5.99)
Other: COCOFU Micro USB Cable,3FT 6FT 10FT Nylon Braided Micro USB Cable(Black+Gray)(3Pack) (Purchased For $8.85)
Other: 60mm Black Finger Grill / Guard (Pack of 4) (Purchased For $8.50)
Other: Xbox Wireless Controller and Play & Charge Kit Bundle (Purchased For $74.99)
Other: 3M Scotch Heavy Duty Mounting Tape, Clear (4010) (Purchased For $5.43)
Other: 6ft - U-channel edge molding for PC panel mod windows (Purchased For $3.99)
Other: ModMyToys 3-Pin Power Distribution PCB - 3-Way Block (plus 3-pin Female-to-Female 12") (Purchased For $11.13)
Other: M1 Single-G mini PC Case Feet - Silver (Purchased For $24.99)
Other: Smoked Tinted Transparent Cast Acrylic Sheet 12" x 12" x 0.118" (1/8") Gray (Purchased For $9.75)
Other: 44 Keys Mini IR Remote Controller for 3528 & 5050 RGB LED Strip Lights - US (Purchased For $3.75)
Other: Vandal Resistant Illuminated Momentary Switch - Silver - 18/16mm - White Ring (Purchased For $11.95)
Other: x50 - Female ATC Terminals (Purchased For $2.95)
Other: 8-pin PCIE Female Connector - Black (Purchased For $0.59)
Other: 24-pin ATX Female Connector - Black (Purchased For $0.59)
Other: Black MDPC-X Small Sleeve (50ft) (Purchased For $14.98)
Other: Original MOLEX Pinremover - MDPC-X Edition (Purchased For $19.99)
Other: MDPC-X Crimp Tool (Purchased For $47.99)
Other: IEC 320 C14 Male Plug (Purchased For $0.99)
Other: IEC C13 C14 Male Female Inline Chassis Socket Plug Rewireable Power Connector (Purchased For $2.46)
Other: 120mm Overkill "Ring" PC Fan Grill (Purchased For $0.00)
Other: Modder's Mesh PC Fan Grill (Purchased For $0.00)
http://pcpartpicker.com/b/NNGG3C
- 17Nov16 - Initial Purchases Made, and Updated Parts List
- 21Nov16 - Arrival of First Batch of Parts
- 21Dec16 - Current Inventory and Audio
- 26Dec16 - Final Major Parts Arrive
- 26Dec16 - Close-Ups and Mobo Mod
- 26Dec16 - Test Ghetto Setup
- 27Dec16 - GPU Ventilation Holes Cut
- 27Dec16 - Internal Shell Removal
- 28Dec16 - Front Panel Grill Removal
- 28Dec16 - Case Feet and Power Button Replacement
- 29Dec16 - Rear Fan Installation
- 31Dec16 - PSU Mounting
- 02Jan17 - PSU Power Pass-Through
- 02Jan17 - ODD Tray Mod
- 02Jan17 - Side-Panel Window Cut and Mounted
- 03Jan17 - Rear Fan Bracket
- 03Jan17 - Case Mods Completed, Fans and PSU Installed
- 09Jan17 - PSU Cable Sleeving
- 09Jan17 - Final Assembly, Part 1
- 09Jan17 - Final Assembly, Part 2
- 09Jan17 - RGB LED Explanation
- 10Jan17 - Final Photos - Day-Light
- 10Jan17 - Final Photos - Night and LED's
- 12Jan17 - Seeking out Replacement PSU
- 21Jan17 - Replacement PSU Woes
- 21Jan17 - New PSU Mounted
- 21Jan17 - Benchmarks, Overclocking, and Validation Links
