So the case on my sig is what im using now, but over the year that i have had it, its been moved around and it seems to be breaking here and there. I also want to cut the fan grills off smoothly but im not too sure what would be the best method to do so. Another thing i need is quieter fans, im currently running all 140cfm Panflos and at first i loved them, but now that ive moved to a bigger apartment, my case echos thru the bedroom with all the ruckus the fans make. Can you guys recommend the following...
1) Case fans X3
2) A method for cutting out the fan grills
3) Should i even bother and just buy a new case?
PS - The front panel is somewhat broken as its flimsy and annoying.
1) Case fans X3
