1 - 3 of 3 Posts
Amiga 500
Depending on how you're going to mount them,there are various sizes..
Usually 10 or 12mm will do the trick
EDIT :
where exactly in the case do you want to add fans?Front intake?Side?
Because according to the manufacturer's manual,the front intake fans will need longer screws , like so :
If you want to add front intake fans you need the long screws..Maybe take one out and measure it,although it seems like 25-30mm
Otherwise standard fan screws that are included with the fans you'll be buying will do..
Reactions: saywhuut
EDIT :
I'm going to be installing one on the side and one in front. Thanks for your help
1 - 3 of 3 Posts
