Need to get a decent but cheap case i.e. under £100 and need suggestions on what to go for.
I'm not fussy on size as long as it can fit my components then its not a problem. I need something with a motherboard tray that is removable as well as tooless installation on hdd, cd/dvd and expansion slots and decent cable management would be good good too.
Can i get a case with all the features i suggested for under £100??
The Anttec 900 II is nice and cheap at overclockers at the moment.
And it's a brillient all round case.
Cooling, space, ventilation, easy fitting, everything.
I don't know of any cases with removable motherboard trays, but as first few suggest cases without removable motherboard trays I figure I might as well too. The HAF932 doesen't have a removable motherboard tray, but fits most of the other categorys, and is ~150$ (I think).
The 690 has a cable management hole right next to the psu to allow you to route all the cables behind the (non-removeable) mobo tray. Only difficulty I've had is the bundled real power pro 550W PSU doesn't have a long enough ATX connector to reach if I route it behidn the mobo tray - an HX620 does reach though and of course you can make another hole in the tray or get an extender. Overal I'd rank the cable management as excelent, with just a point taken off for not thinking though the cable length if you go for the bundled psu.
The cable management is top notch, check out the "Rate My Cables" thread, a lot of people there have CM690s that have hidden their cables damn well. Without drilling any holes at that. (Including myself)
Overclock.net
