1 - 20 of 1335 Posts
Enthusiast Cases
We are pleased to officially announce our newest prototype case line in the works, the NOVA X2, X2M and the X5.
First X2 prototype:
There are MANY changes coming, but here are pictures of the general layout
(beside a S3 for reference.)
From left to right; X5, X2M, X2
NOVA X2
NOVA X2M
NOVA X5
Spec list as of Aug 12, 2014 (SUBJECT TO CHANGE)
* All aluminum construction
* mITX and mATX form factors
* Reversible
* Full-size PSU support
* Supports full length video cards (2.5 slot cards okay)
* 240/280 radiator support in the roof with 55mm clearance
* 170mm cooling tower clearance
* 55mm of radiator clearance above motherboard (in a standard configuration)
* Removable motherboard plate
* Flex-Bay system (X2M only)
* Screwed together chassis
* Quick release exterior
* Extended tops and Pedestals will be available (excluding the XM2, for now)
* Drive support TBD
* Exterior dimensions TBD
* Price TBD
Official X2M Specs, Options and Pricing.
Base Price: $199.95
Color
Black - $0.00
White - $20.00
Gunmetal - $20.00
Primer - $0.00
Two Tone - $30.00
Orientation
Standard - $0.00
Reverse - $0.00
Top Cover
Standard Vent - $0.00
Standard Solid - $0.00
36mm Ventilated - $20.00
Motherboard Side Door
Solid - $0.00
Window - $20.00
Flex-Bay
Solid - $0.00
Ventilated - $5.00
120.2 mount - $20.00
120.2 mount with HDD cage - $44.00
120.2 mount with 2 HDD cages - $68.00
Power Switch
Yes - $0.00
No - subtract $10.00 (switch mount included)
I/O panel
None - $0.00
USB 3.0 w/ HD audio - $15.00
Divider Cover
Yes - $10.00
No - $0.00
Other info:
Dimensions: Depth: 16.69" / Width: 9.06" / Height (without feet): 15.63" (424mm x 230mm x 397mm) CASTERS WILL NOT FIT THIS CASE
Distance from divider wall to inside of motherboard side door: 7.8" (198mm)
Distance from PCI backplate to Flex-Bays: 16" (406mm)
Distance from PCI backplate to Flex-Bay 120.2 mount: 15" (380mm)
Distance from the top fan mount to the top of the motherboard tray (rad clearance) in a standard configuration: 52mm
Distance from the top fan mount to the second PCI slot (rad clearance) in a reverse configuration: be announced later when I measure it tongue.gif
Weight: 10 pounds (4.5kg)
PCI Slots: 2
Native SSD mounts: 0-4
Native HDD mounts: 0-4 (only 2 positions can be used at once)
Total possible HDD capacity with extra mounts: 10
Total possible SSD capacity with extra mounts: 20
Top Fan Mount: 240/280 universal
Bottom fan mount: 140mm
Rear Fan Mount: 120mm
Number of Flex-Bays (5.25 bays): 6
PSU support included
I miss my OCN!!
Kickn' ars and taken names as usual, looks nice.
Make sure it can fit 9.7" Deep hot swap bay :)
Originally Posted by geggeg View Post
Saw the tweet about this, this needs to be a bigger deal already!
When those who want to use an AIO unit in a small form factor chassis, but don't have a small form factor chassis from the maker of said AIO see this, it will be.
As usual, it will support Air, AIO, and water. It's a CaseLabs case. And when you need that extra oomph for cooling your Titan (or next big name GPU), there's always a pedestal.
This might be my next case. I can't wait to see how it develops.
Call me VSG
Originally Posted by XNine View Post
Check.
Now I feel like I should get this instead of the Ncase M1 V2 (terrible naming that) for an HTPC build. It would be amazing to put this wee thing next to my TX10-D w/extended top and pedestal for a photoshoot.
you guys should mount the psu in the front leaving the top and bottom for radiators....
