Hello,
I did not see any DEMCIFLEX MAGNETIC FAN DUST FILTER for the SMA8 for the TOP and BOTTOM of the 560 radiator and PSU area? But I do see they make a CUSTOM 5 PIECE SET FOR CASELABS MAGNUM STH10. Now my question is will at least 3 pieces work with my SMA8 I have on order? I would like to place the filters on the inside of the case like pictured below if I can. 2 x at the bottom section and 1 x at the top of the case. If I have some filters left over no problem just save them for another build later.
Also I bought a 3 x 120mm flex bay mount for the case and I see they make a DEMCIFLEX MAGNETIC FAN DUST FILTER I plan on buying that as well.
Thanks
Thanks
