Hello, I am working on TX10D planning and struggling with the options.
On one of the chamber sections, with power supplies installed is there enough room to have 120.4 MAC-192 mounted and populated?
It seems that a large PSU 186mm long power supply and a 522mm long radiator seem like they would work, but the spacing seems to be generous in the corners.
Or similarly on the upper chamber, with power supplies installed is there enough room to have MAC-196 super mount installed and populated? It's not clear if the supermount is offset at all, or a complete cover.
When comparing with the TH10, the TH10 would no room, but is not as deepas the TX10
Regarding the cable management holes, I assume they are the four holes in this picture? Or are they the three rectangular holes between the chambers?
Thank you.
Thank you.
