1 - 6 of 6 Posts
As a side note, I've built several computers before; my current system is an i7 920 with a GTX 580, both running on water. Right now I'm looking to build another desktop. I do a reasonable amount of gaming\\video editing\\general computer use. I need a SLI\\Crossfire setup to run 3+ monitors. My current build (thrown together in about 30 minutes, so no guarantees that's it's perfect):
http://pcpartpicker.com/parts/partlist/ar/m32
I narrowly chose the 2600k over 2500k due to hyperthreading; I plan to push it to around 4.6-4.8, or whatever I can get with my cooler without destroying it in the long run with high voltage\emps.
Well if you do a lot of rendering at high resolutions, then the 2600k will help.
Mobo, I guess the biggest factor between the high end ones would be chipset cooling and color scheme.
http://motherboardnews.com/2011/05/1...eview-roundup/
Thats a link to a website that has a fair amount of motherboards and reviews linking to each.
Good looking build but 16GB of RAM isn't necessary. I personally wouldn't buy a Thermaltake PSU either, go with a Corsair HX750.
edit: Nvm I looked that PSU up and it seems pretty good.
Discussion Starter · #6 ·
I run a fair number of VMs, and my current machine is 24 Gb, so I don't think going less then 16 is a good option - I'll upgrade to 32 when it becomes available.
I'm actually considering putting this PSU into my old machine, which is currently running a Corsair HX1000, and putting the Corsair into my new build.
Whitepants, thanks for the motherboard link - I'll look through that site.
1 - 6 of 6 Posts
