1 - 6 of 6 Posts
Can anyone suggest a good case with the window on the right hand side? I've moved my desk around to prevent the monitors from reflecting on our new TV but now the window of my 600T is against the wall. I've been looking at the Silverstone Raven RV02B-EW but just wondered if there are any others I should be looking at within the same price range. Thanks.
Well, basically you have the Raven 2 and Fortress 2. But other than that its a bit difficult as most of those with windows on the right hand side would also have inverted ATX setups. There is a cheap one by Bit fenix as well, if I am right.
That is correct. The BitFenix Outlaw. However, you would need to mod your own window in it.
1 - 6 of 6 Posts
