Let me see if I can explain this right. Let's say I have pre-made cat5e. It is terminated type B. The plug in the wall is type A and runs to the other plug on the other end which is Type A. The cable on the other side is type B. Is that a problem? Because most of the pre-made cables I see are type B.
Actually, what is better? Type A or type B?
Another question. What is the maximum length you can have a stranded cable. Monoprice sells 100' cables and say they work great. I have talked to people and they say they are great. What is your consensuses?
