1 - 4 of 4 Posts
Ok so basically I got my new motherboard 890FXA-GD70 MSI and I installed my two cards into it. Booted fine and the bios updated to 1.80 fine.
So basically now my CCC will not start. I can overclock using afterburner so windows is holding the cards fine. But I can not adjust any of my quality-performance settings and its really getting annoying. It just goes and says "CCC has stopped working checking for solution". I will post a pic just to let you see what it is doing.
If I can get this fixed that would be amazing because I have literally tried everything. Thanks!
Tried running something like Driver Sweeper before reinstalling drivers?
· Premium Member
Reinstall your graphics drivers. Easy way to do this.
1. Download the latest drivers, 11.4... or 11.2 (11.3 is buggy).
2. After downloading them, run the setup EXE.
3. When you get to the Install/Uninstall screen, select Uninstall first and Uninstall your old drivers.
4. After that, choose Install.
5. Install drivers, restart.
Hopefully everything should be working fine by then.
1 - 4 of 4 Posts
