Catalyst freeze
427 Views 4 Replies 3 Participants Last post by  cky2k6
Whenever I try to use auto tune in catalyst, it just locks my display up, though the pc isn't frozen. I thought it was a driver issue at first, but in windows 7 and a new catalyst it still does this. Could it be a power problem?
1 - 5 of 5 Posts
How is your idle temp. before you adjust the ccc auto tune?
temps are fine, hottest core is 55c. it doesn't run then crash, it locks up as soon as it even tries to run the test.
Just a thought, but its probably an issue with windows 7 as ccc is not supported properly with the 9.2's yet in 7, but the 9.3 released on the 18th is supposed to have 100% windows 7 support.
happens in vista as well...
1 - 5 of 5 Posts
