Causes for pump vibration?
712 Views 10 Replies 7 Participants Last post by  Bindusar
Hi all. I have a Swiftech MCP655-B on my current rig which has been running 24/7 for about 3 months now. Lately I have noticed that the pump is starting to vibrate and slowly getting louder. It's kind of funny since it is hanging on an exterior wall you can hear it outside because the aluminum siding is vibrating too!
Any ideas as to why this would be happening? I haven't tried taking it apart since it would be a PITA (see the pic). I have a second one sitting idle in my old rig that I could swap out if I need to. Just thought I'd ask and see if anyone else has had this issue and whether it had a simple fix or not. My other pump ran for a year and never developed this.
1 - 11 of 11 Posts
My guess would be the propeller isn't spinning correctly. Maybe you have build up of some sort and it is causing the propeller to hit it. Or it's out of wack somehow. Your only option is to probably take it apart and see it you have buildup on one of the paddles of the propeller. Sorry, that probably didn't help much.
Funny thing is that I don't see any buildup in the res or the tubing. Hmmm...I just realized that my pump is the lowest point in the circuit, While I can't really imagine sediment being able to settle in it given the turbulence I guess it is a possibility. Yeah, sounds like a tear down is in order. I'd rather wait but since it is a balance issue I know leaving it be will just hurt the pump. Dang.
That could very well be it. The impeller is the only moving part, it rides on a little ceramic bead.
If one of the vanes isn't plugged up it may be the little metal seat in the bottom of the impeller that the bead goes into. If thats getting a little worn (the metal seat) it could make it whine. Maybe try a tiny bit of hi temp white lithium grease and see if it stops it. I know on a couple of the Laing pumps there has been a little bit of some blackish grease on the bearing when I opened them up, I mean a real tiny amount..
This is a old DDC, the D-5 is about the same, the pump inlet is just orientated differently, just pull the impeller straight out, its just the magnetism of the coils holding it in.
Sharp rig you have there, looks good!
I don't have water cooling myself bit I do know a bit about how pumps operate.
Can you unfix the pump from the case and waggle it about or give it a light tap or two just to check that there's no air locked in it which can cause vibration.
If no air or debris is present I would suggest that maybe the pump impeller has become imbalanced through either wear from rubbing against something, or maybe even the the pump bearings are wearing unusually quickly causing play/vibration in the shaft.
If you can try your spare pump and all is ok, I'd say return the one your using as faulty?
off topic.. Awesome PC setup. That looks amazing.
This was the one other concern I was eluding to but figured the turbulence would purge it. I am betting that is what it is. If you look at the pic you can see that my res is directly above the pump. The way the water flows into it causes a churning and some bubble formation. I am of the mind that over time the fine aeration has made it into the pump and I bet it has collected. Servicing it will be a pain but I think I can do it without having to tear it apart too much. I'll also top off the res so that the return doesn't cascade into it and cause the aeration. Hopefully that will do it. Thanks guys!
DigitalBear...thanks. It was going to be my case mod entry in the last contest we had but some stuff didn't show up in time and a few things caused me some trouble so I had to pull out.
Originally Posted by LiquidForce
A pump cleaning would be the first thing i would try
btw how does that copper coil work as a rad?
Like a passive rad but with the fans blowing across the tubing it cools it down... I think.
Maybe the pump trapt air inside?
how meaning performance wise, i should have been more specific.
and doubtful about the air seeing his orientation of the pump
Well, I took the pump out and opened it up...nothing to be seen as far as crud. I tried running it for a couple seconds dry (yeah, I know you're not supposed to but they can handle a few seconds) and the vibration was still there to the same degree as it was originally. I noticed the small lead weights (this one has 3...maybe I'll snap a pic later) and using a small jewelers screwdriver to check they all seem tight.
Long story short ending, I scavenged from my last rig that I'm not running anymore...same pump but with the Laing sticker instead of Swiftech. It has been sitting dormant for about 3 months. Took it out, hooked it up, added more water and started her up...silent as always. If I hold it you can still feel a little something but it isn't enough to cause noise. We'll see if this changes over time. Doing this though now makes it official that my last rig is no longer going to be used so I have to decide what to do about/with it...an old AMD 3200 with a BFG 6800 AGP video card and 2GB of ram. Decisions decisions.
About the homemade rad/heat exchanger...doesn't work too badly. I'm not out to push this thing so I am only running 3.6 right now (no power increases needed) and it is running right around 51-52C at the high end (folds 24/7). I don't think that's too shabby for what I got...uneven, non symmetrical coils that were hand bent around a 3" diameter x 6' long piece of PVC. The tube it's in only leaves about 1/4" gap per side clearance. I also added a center tube to ensure the airflow went over the coils and not into the middle and then back out at the last coil. That one has mabye 3/4" clearance to the coils. It is basically the diameter as the center hub of the fans.
1 - 11 of 11 Posts
