1 - 17 of 17 Posts
Got my new build done wednesday, sig rig. 1tb caviar was just gonna be used for storage. I put maybe 35 pictures on it, went to put some more pictures on it tonight and its not showing up in my computer or in bios. I switched it with were the ssd drive(hot swap bay) is to eliminate the plug itself...only other reason is...completely dead...do they just quit working like that?
Originally Posted by Twister773;12969906
I checked everything, it has to be the drive. Not a big deal. I read they were the most reliable which is why i got it. There is always gonna be a few that fail. I just filed the RMA online with newegg and got an email approval. Gonna ship it off tomorrow morning.
Okay.
Good luck man.
Most of the problems with HDD's come from shipping companies and their rough handling of boxes. Desktop drives are much more subject to shock damage than their laptop variants are (due to the design parameters, they are better able to absorb shock).
That said, there are just simple cases of bad units making it through quality control. No matter the manufacturer (though, some are not so careful during QC), it's just a fact of life. Sorry for you luck, hopefully you'll have better on your replacement.
· Premium Member
Give this a shot, OP!
Click Start, RIGHT-click My Computer in the window, then click on Manage from the menu. In the new Computer Management window expand "Storage" if necessary and click on Disk Management. Now, examine the TWO right-hand panes. The upper one shows you only the devices Windows already knows how to use. The lower one, which SCROLLS, also shows you other devices Windows does not yet understand. Your new disk should be here with no letter name and no info. RIGHT-click on it and, from the menu, choose to Partition the drive. You'll have a choice of how big it should be and most likely want to use all the drive in one volume. (You can use only part of the space. If you do, when you are finished come back here and find the remainder shown as "Unallocated Space". You can create a second Partition or more in it if you want.) For this first Partition, make it the Primary or Active Partition, and NOT bootable because this drive is for data only - you already have a boot drive. When all the choices are made, go ahead with the Partition operation.
When that is done, come back to this new Partition and RIGHT-click again and choose to Format it. Choose the NTFS File System option. A Quick Format will do the job in 5 to 15 minutes. A Full Format will do a Quick Format, then go though every sector of the drive and test it, marking off any faulty ones (very rare) so they won't be used. Full Format takes many hours!
1 - 17 of 17 Posts
