Just a heads up if you use CCcleaner and CCC. If you use the registry cleaner option to remove unused registry entries it removes some in use for AVVIO, I was wondering why when I went to vivvo(the part with flag moving) it crashed. Turns out CCCleaner removes and entry it need's. So save yourself the hassle of having to uninstall then install again by just not letting cccleaner delete them entries.
Someone else had the same problem here:
http://forum.piriform.com/index.php?showtopic=18956
EDIT: Added entries for cccleaner to ignore:
