Originally Posted by Lshuman
I used it on my MSI 5770 oc and I got the yellow screen also, but I could still use my compuiter. It may seem like it locked but its not, just hit the windows key on your keyboard and you can see that its not locked.
This is what I got:
GPU-Z 0.4.0GPU-Z Validation vbsbc
Card Name: ATI Radeon HD 5700 Series
Owner: Lamont Submitted: 2010-03-28 02:23:59
Owner's Comments:
GPU: Juniper Revision:
Technology: 40 nm Die Size: 170 mm²
BIOS Version: VER012.014.000.001.034761 Device ID: 1002 - 68B8
Bus Interface: PCI-E 2.0 x16 @ x16 2.0 Subvendor: MSI (1462)
ROPs: 16 Shaders: 800 (DX 11.0)
Pixel Fillrate: 15.2 GPixel/s Texture Fillrate: 38.0 GTexel/s
Memory Type: GDDR5 Bus Width: 128 bit
Memory Size: 1024 MB Bandwidth: 89.7 GB/s
Driver: atiumdag 8.14.10.0735 (Catalyst 10.3) / Win7 64
GPU Clock: 950 MHz 1435 MHz
Default Clock: 865 MHz 1200 MHz
Overclock: +10% +20%
Hi, I also used the ccc auto tune, (I also have a AMD 965BE o/c to 3.69 and a ATI HD 5770 card), just a few hours ago. It set me to 940 or 945MHz but left my Mem Clock at 1200!?
So I made the Genius move of pressing that button, (re-auto tuning), and the system started auto tuning from the default again. But this time I saw that it had got to at least 945 and then I was called over to the other room by my wife.
I was only gone a minute but when I got back, the computer was restarting. Then, as it completed the loading of my desktop Icons it suddenly crashed and went back to restarting!
I have not successfully started the computer since then! I can’t keep it open long enough to set my CCC back to a position that will not be so unstable. I can start in Safe Mode but I don’t know what to do when I’m in that mode.
I tried going back in time with a restore point that was set 3 days ago but still no luck. I’m desperate for any suggestions that I can get on how to turn back the GPU so I can keep the computer on!
I have Windows 7 Home Premium 64bit, 8gigs ram and I already stated my CPU and GPU specs.
I used the AOD in “Novice†mode and ran the Auto Clock for the CPU. That worked nicely and brought my 965 from 3.391 to 3.691. That has been running like this since yesterday.
But the GPU setting is what I think the problem is. I just can’t keep the computer open long enough to turn it back. Can anyone help?
