I have 4 dual inverters and 8 new 12" UV tubes, which I really would like to wire to a single toggle switch. I have read about some issues people have had with using different brand inverters on a single molex, and wondered if that's something I need to be careful of. I know that at least 2 of them are different, but it's possible I have as many 4 different brands. Should I reconsider being able to wire these all together to one switch unless the inverter's guts are the same?
Also, I wondered if I needed to be concerned about having four inverters on a single molex, even though the total output is only around 14 watts (assuming my calcs are correct: 680V X 5mA = 3.4 watts per inverter)
Here's the wiring plan, but if using the same inverters is a real concern, I'll have figure something else out for now.
