CD ROM Cable
706 Views 13 Replies 10 Participants Last post by  blupupher
Anyone no how to replace the ennoying IDE cable going to and from my CD ROM Drive? like is there a smaller hook up I can use?
1 - 14 of 14 Posts
You could either get a round IDE cable, or a SATA CD drive.
will the SATA cable work with most CD ROM drives?
Pfft dont buy a round one just get cable ties and make the fat ones round I DID and it works ok but isnt very bendy.
If its a SATA CD/DVD Drive, yes. If its a ribbon cable, then no.
How can I tell, there are two more types of connections to the left of the IDE connection, now if it is a sata connection do i hook tht right up to the Sata conection on my mobo?
I dont think any DVD drives have SATA and IDE.
he might be looking at the ide jumper block and thinking its a second, smaller connector
Yeah, there aren't DVD drives with sata and IDE. If you want, you could buy a new DVD drive and sata cable, but for now, a rounded IDE should work just fine.
Honestly, I would just get a SATA drive. A decent one will set you back $25. How much are you going to spend on a cable, anyways?
edit: I had a few set-ups with round IDE. While they are better than ribbon, I still didn't like them. Still bulky and I always had a hard time getting the end covers to stay in place. (could've just been the cables I was using, though.)
Im gonna just go with a round cable, I think I found one at best buy i can use its all black which works with my case, but maybe later ill go with a sata connection
Round PATA cables are fat and stiff IMO, but in this economy go for it
. Or maybe you can auction your drive and get a cheap SATA one, how much does the cable cost anyway? 5? maybe you can sell your drive for 15 and buy a 25 one, you'd be spending just $5 more than if you got a pata cable
You may spend more for the cable at best buy than you would getting a new drive from newegg.
1 - 14 of 14 Posts
