1 - 7 of 7 Posts
k i hav an emachine, since i cant overclock thru the BIOS im trying 2 overclock thru ClockGen(latest ver), now i folowed the directions from thier site and i got stuck on finding the PLL cuz i cant find where my cpu fits on their site cuz 1st i tried 2 put the PLL on ICS 952618 since i hav an intel but nuthin happened when i went 2 the PLL control pic <a href="http://www.itsgameover.com/forum/uploads/1376untitled.PNG" target="_blank">here</a><br><br><a href="http://www.itsgameover.com/forum/uploads/9233untitled.PNG" target="_blank">another pic here</a><br>
so yeah im not sure wat 2 do now im i missing sumthing like did i put the wrong PLL?????<br><br>
heres pics of my pc from CPU-Z<br><a href="http://www.itsgameover.com/forum/uploads/9225Untitled-3.png" target="_blank">pic1</a><br><a href="http://www.itsgameover.com/forum/uploads/22Untitled-2.png" target="_blank">pic2</a>
go to the cpuz website, check lower down the page and it will tell you the most common IC number that corresponds with your chipset displayed on cpuz. Then, you can take that number and give it a go. Caution: I fried my laptop this way...
at your own risk!!!!<br><br>
try ICS 9526XX... the xx stands for numbers unknown. This worked for two of my last three laptops... Dell's...
Discussion Starter #6
k open up my pc and ound out my PLL is<br><br>
952601 and i guess clockgen does not support it so can any1 help me out here on wat other software should i use
Best thing is to look for a new board if you can find one get a used Asus p4p800 series board.
1 - 7 of 7 Posts
