1 - 7 of 7 Posts
EVGA X58 board. The top (primary) PCIE lane is empty due to the use of a sound card which blocks it. So I have the cards in lanes 2 and 3 and both device manager and Cat are only detecting one card. Any ideas?
Thanks.
I would test with the sound card out and the video cards in 1/3 or 1/5 to see if they work with a normal configuration. If it works, just put the sound card below your cards if going 1/3 or between them if going 1/5.
But what kind of sound card are you running that blocks a slot below it? That thing must be honkin'.
Move your sound card to ANY other PCIe slot...
Originally Posted by kz26
Why is your sound card in the primary PCIe slot? Put the GPUs in 1 and 2 and the sound card in the last slot.
The "primary" slot is empty. I think he's saying his sound card is in one of those PCI-E 1x slots that some boards have at the top. I still don't get how the slot below it would be blocked though.
Reactions: Slightly skewed
Discussion Starter · #6 ·
Correct!
It's a Xonar STX and it's the board's layout combined with the large stock 5870 cooler that's the issue. I'll move it to another PCIE slot and see if it works. I hear that it's doesn't fit so well and some have problems running it in a graphics card slot.
1 - 7 of 7 Posts
