This is a really bad idea. I know because I did it. When you have two GPUs in crossfire that are not identical, you get something called "runt" frames which create a ton of microstutter which you will see and which will ruin your gaming experience. I found that the single 7870 looked smoother than the "frankenfire" setup.
The new 13.8 beta driver will definitely help, but my advice FWIW is to buy a 7950 or a 7970 and sell your current card. You won't regret it.
