My initial thoughts:
- Fractal Define 7 XL (unsure what the best case fan configuration would be)
Noctua RTX 3080 - Arctic Freezer II 420 CPU cooler (or possibly NH-D15/S, Le Grand Macho RT, Jonsbo HX7280 with 140mm fan(s), but I am concerned about their performance at sustained loads in a relatively limited airflow (but quiet) Define 7 XL case)
- Alternatively, Monsterlabo's The Beast case might work, but it would require undervolting the CPU and still require a fanned GPU, because its passive heatsink is designed such that both the CPU and GPU cannot run at full load simultaneously for more than a few minutes.
- I am aware that both the CPU and GPU running simultaneously at full load represents almost no real-world workflow, but I want to optimize for the worst case scenario while maximizing performance and noise.
- Let's also assume that moving the PC into another room and routing cables is not possible.
- I would like to avoid fully custom water loops if possible.
