Change default search to Google
374 8
Some POS program forced my search to Yahoo
My search bar says Google yet if I use the address bar to search anything it redirects to Yahoo :swearing:
Helllllppp meee I want my Google back
1 - 9 of 9 Posts
Originally Posted by xxicrimsonixx View Post
http://www.firefoxfacts.com/2008/01/...ch-in-firefox/
Does not work, I tried
Originally Posted by ChristianEx View Post
Hmmm... strange..
Do you have Yahoo on the list of search providers? If so, delete both Yahoo and Google and try adding Google as the defult search engine and see if that helps..
Nope, removed all but google
Goto you add-ons tab and check to see if anything is installed there that would be doing it. If so disable or uninstall it there.
Originally Posted by XFreeRollerX View Post
How do I remove about:config entries?
check this out: some of these lines match whats in the search bar
Instead of deleting it, see if changing the User Settings or Parameters to something will make it stop. Otherwise, you could always backup your book marks and reinstall Firefox.
Or try setting it to this: (See attached picture)
Discussion Starter · #8 ·
THAT LAST VALUE, keyword.url
THAT was pointed to yahoo, I reset it back to google and it came out similar to yours
EVERYTHING WORKS NOW!!!!
1 - 9 of 9 Posts
