Originally Posted by
krista031
i believe that icelandic language pack is supported by windows.. so if you dont have it in yours try updating your windows, update should be under additional updates (or whatever theyre called).. if theyre not, click on the left side 'Restore hidden updates', update should appear somewhere between all of them..
later in region&laguage settings you can set the keyboard to have multiple input languages between which you can switch with the shortcut (combination of keyboard keys) of your choice..
