Change IP?
493 Views 11 Replies 11 Participants Last post by  stanrc
Hi I was recently banned from GTA:SA roleplaying server when I went to the bathroom my friend shot an admin who IP banned me. Is it possible to change my IP so I can play on the server again?
Handing out like candy for those who deserve it.
~B~
Status
Not open for further replies.
1 - 12 of 12 Posts
Not possible. IP is ISP Based. I think this is against the ToS too.
If your on DSL, hardboot your modem, turn it off for 5 minutes, and then turn it back on.
If that does not help (which it will 90% of the time change your IP), use a proxy server, or proxy software.
Unplug your modem and plug it back in.
Couldn't you do this in cmd?
ipconfig/ release
ipconfig/ renew
Or would it not work for the game?
call your ISP and ask for a new IP
ipconfig/ release
ipconfig/ renew
That would just change your local/windows IP. WAN IP needs a modem restart.
Alright thanks for all the good replies guys. +REP to all
~B~
EDIT: Also, excuse me if this is against the ToS.
~B~
Perhaps if a website exists for the roleplaying server, go on and make a thread requesting an unban?
No, I have been banned a billion times, all you have to do it ipconfig /release as a couple people said.
Talking about IP evasion is against the ToS.
If you want to get back in, just have a word with the admin that banned you. I am sure there is a forum somewhere for that game server, and you can talk to him there.
Changing your IP to avoid a ban is against the TOS. If you were banned then you need to take it up with an admin on that server to get it sorted out.
Some ISPs assign IPs based on the modem serial number so even if you reset the modem it may not pull a new IP. Although they usually rotate IPs to keep people from hosting websites off of them that would require a static IP so they can charge more for it.
ipconfig /release and /renew won't work unless he's directly behind the modem. If he's behind a router then it only changes his internal IP, which the game server doesn't see.
1 - 12 of 12 Posts
Status
