1 - 9 of 9 Posts
I have to go default or back stock to change memory stick's for different ones?Or just put it in?And start OC again from 200 up?
I'd go as far as the clear CMOS and start all over again.
OCN Dinosaurian Member
Just change them out and go from there. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> If you have any problems go to default, but you shouldn't have any.
<tr>
<div>
Originally Posted by <strong>Chozart</strong>
</div>
<div style="font-style:italic">I'd go as far as the clear CMOS and start all over again.</div>
</td>
</tr>
</table>
</div> Wow, I never had to do that. Maybe I was just lucky. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Discussion Starter #5
Want to try again the G.skills pc 4000 HZ.I prime once with those stick's but @ 2.5 no problem's.once pass the 2.5 to 2.6 problem's start.But I never went back to stock or clear cmos.If I go in the mobo and go default that should do It or I have to remove the battery?
<tr>
<div>
Originally Posted by <strong>Compaddict</strong>
</div>
<div style="font-style:italic">Wow, I never had to do that. Maybe I was just lucky. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>Yes, that would be luck... Not all ram can run the same timings /frequencies as others at given voltages... its best to change the ram and start clean...
Discussion Starter #8
OK.That's what I think it happen.I just put it in and go.You think im going to gain performance going from xms pc3200.to pc 4000?This is now?<br><a href="http://assets.overclock.net.s3.amazonaws.com/3/31/31777120_vbattach33167.jpeg"><img src="http://www.overclock.net/image/id/617106/width/525/height/525/flags/LL"></a>
<tr>
<div>
Originally Posted by <strong>pbasil1</strong>
</div>
<div style="font-style:italic">Yes, that would be luck... Not all ram can run the same timings /frequencies as others at given voltages... its best to change the ram and start clean...</div>
</td>
</tr>
</table>
</div> That makes sense. Now that I think of it, I probably had everthing in auto back then. <img src="/images/smilies/doh.gif" border="0" alt="" title="Doh" class="inlineimg" /> <br />
<br />
Well I learned something today, thanks! <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
1 - 9 of 9 Posts
