Edit: Initial problem solved, now have access to my BIOS once more after resetting the BIOS. Now, just need assistance with proper voltage/clock settings for achieving 1100 RAM speeds.
Hello everyone, have a problem, not sure the reason - need some help.
Not knowing whether or not this is a general issue that could be answered and solved on the fly, I'll start by giving some simple information.
Gigabyte GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard
AMD Phenom II X4 940 Deneb 3.0GHz
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1100 (PC2 8800) Dual Channel
Etc. Basic information.
I built it a good few months ago, and have for the most part had no issues whatsoever. However, I never bothered to get the RAM running at its advertised 1100, it was always running at 1066 from default settings. The only real problem I ever had was sometimes it would take a long time for the computer to load, but it was hit and miss and simply restarting usually fixed the problem. Today I opened up the BIOS menu upon starting it up to check the settings, and the only setting I changed was I changed the RAM settings from "Manual" to "Auto" - which didn't actually change any of the set voltages or timings to my knowledge.
I'm not extremely knowledgeable when it comes to BIOS settings, but that was all I did. Changed "Manual" to "Auto" and after saving and exiting the BIOS window, I now cannot get my computer to load whatsoever. Start it up, and it sits at a black screen indefinately. No text, no messages, no noises. Everything in the case seems to be running fine, great as always. I'm just not able to get any farther than a black screen.
I've let it sit for as long as 40 minutes, and still nothing. I'm about to run out now for a couple hours or so to see if that miraculously does anything, hopefully getting responses here in the meantime.
So question being.
What the hell? "Auto" was actually the default upon setting it all up for the first time months ago. Why would the automatic settings magically cause the computer to not start up? Especially when they're the same settings they were set to in "Manual"? I now can't even get far enough to get back INTO my BIOS menu to change it back, leaving me, who is not so familiar, powerless to do anything.
Any and all help is much appreciated.
