1 - 8 of 8 Posts
Is there a way to get game files on a computer directly to ISO without burning it to a disc?
You mean use an ISO image without burning it to a cdrom? Yes. Mount the image with Daemon Tools, it will come up as a virtual drive.
I mean if I have the files, but they arnt in an ISO format. They are the files you would find if you browsed the CD. Is there a way to directly turn those to a ISO?
Does this work with programs that have files from multiple CD's?
1 - 8 of 8 Posts
