1 - 7 of 7 Posts
<tr>
<div>
Originally Posted by <strong>brock4282</strong>
</div>
<div style="font-style:italic">Posted 8/29/2003 by TweakXP Member<br />
<br />
This is not mine so I cannot take credit but Andy-S in the Hardware and Drive Support forum passed this one on to me - a must know tweak. <br />
<br />
Before you swap out the current motherboard go to device manager and select the IDE ATA/ATAPI Controller and select your current storage controller. Right click, select update driver and select install from a list or specific location. Click don't search I will choose the driver to install and select the standard dual channel IDE controller.<br />
<br />
This will prevent the inaccessable boot device blue screen. I have done this multiple times on different platforms with no problems.<br />
<br />
Also I found that booting the first time with the new motherboard is best done in the Safe mode where XP will install the drivers it needs and at the same time you can install the new motherboard drivers from its CD.<br />
<br />
This saved me doing a repair or a reinstall of XP. My whole system came right up and worked great and very stable.</div>
</td>
</tr>
</table>
</div><br />
this is great if it works you wont have keep reinstalling windows xp each time you put in a new motherboard
I just uninstall the chipset drivers then when the new mobo is installed use the new drivers
Do you still have to reactivate?
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>frostbite</strong>
</div>
<div style="font-style:italic">I just uninstall the chipset drivers then when the new mobo is installed use the new drivers</div>
</td>
</tr>
</table>
</div><br />
thats what my post said <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
<tr>
</td>
</tr>
</table>
</div>Thats not what it say at all
Discussion Starter #7
<tr>
<div>
</div>
<div style="font-style:italic">Thats not what it say at all</div>
</td>
</tr>
</table>
</div>my bad i knew about that way to but i found this and decided to share it since everyone always complaining about having to reinstall windows after installing a new mobo
1 - 7 of 7 Posts
