LOG:
Friday, November 09, 2013th
Driver not working on your modern chipset? READ THIS
Wednesday, August 28th, 2013
Removing watermark! Run CMD in admin mode (start button -> keyboard type: cmd , Now press CTRL + SHIFT + ENTER same time to accept admin rights).
Saturday, March 09, 2013:
DOES NOT WORK with WINDOWS 8/8.1 32/64. I do not know of a method that works for all mice so please stand by while I do more research and testing
Thursday, May 24th, 2012:
THIS IS ONLY FOR USB 2.0!!!
Updated Guide: Windows XP 64-bit
Saturday, Jan 01, 2011:
increase usb poll rate in ubuntu, follow this guide
Thursday, Oct 07th, 2010:
If your USB port is broken (AKA plug in the mouse and it doesn't detect) try this method. However, like I said before. Not all mouses work 100% with HIDUSBF and sometimes cause random usb errors (due to stock mouse drivers). Please don't worry about this screwing up your pc, delete the driver. Restart and reinstall the driver again
|Guide:|
If your like me and hate default 125hz that all windows install (Unless you modify) here is a quick way to change your USB polling rate to 1000hz (1.00ms response time).
Windows Vista & 7 64-bit
1. What you need: USB.zip, any link:
http://www.mediafire.com/download.php?71lchfvl8p9cibg
http://www.2shared.com/file/rPJEs6zK/USB.html
http://speedy.sh/nmsYr/USB.zip
http://www.sendspace.com/file/zcgc3m
http://depositfiles.com/files/zh6w5mhcv
http://www.ziddu.com/download/19468303/USB.zip.html
2. Extract HIDUSBF.zip & dimr.exe into a folder
3. Right click on "HIDUSBF.INF" find install (If Warning comes up about unsigned drivers don't worry)
4. Open up dseo13b.exe and check "Enable Test Mode"
5. Reboot
6. After Reboot you will see "Test mode Windows XXXX build XXXX" You can get rid of this but for now reopen dseo13b.exe and check "Sign a system file"
7. In the box type in "C:\\Windows\\System32\\Drivers\\HIDUSBF.sys". If correct a window will come up saying "The system file has been signed succesfully..."
8. Reboot
9. Reopen HIDUSBF folder and click on "Setup.exe"
10. Find your mouse click on it (it should be highlighted has blue) and at the bottom of the window check "Filter On Device" and select your Rate
11. Click Restart and open up dimr.exe. If it's still runs default 125hz reboot your windows Vista or 7 64-bit operating system again
12. To remove watermark open dseo13b.exe and click on Remove watermarks. It will link you to the website with the correct files to remove it
Windows XP + 64-bit/Vista & 7 32-bit
1. Right click on "HIDUSBF.INF" find install
(Note sometimes with XP if you apply and the mouse stops responding in this case restart again and try again)
2. Open HIDUSBF folder and click on "Setup.exe"
3. Find your mouse click on it (it should be highlighted has blue) and at the bottom of the window check "Filter On Device" and select your Rate
4. Click Restart and open up dimr.exe.
|Others:|
Fix mouse with MarkC Windows 8.1 + 8 + 7 Mouse Acceleration Fix, here more here on how to improve game stats
Reboot, watermark gone!bcdedit.exe -set loadoptions ENABLE_INTEGRITY_CHECKS
bcdedit.exe -set TESTSIGNING OFF
Saturday, Mar 26, 2011:
|Guide:|
5. Reboot
8. Reboot
|Others:|
