1 - 5 of 5 Posts
Hello guys,
I just upgraded from an Phenom II x4 955, to the ryzen 5000 series. As part of my upgrade I got a slow cheap 32 Gb kit, Thaiphoon says I got a a-die samsumg mem, they don't oc as good as the b-die right?
Also I'm no expert to the modern overclock but xmp created by the manufactor seem a little relaxed 3200Mhz with 18-22-22-42 maybe has room for improvement, I tried some tutorials with ryzen dram calculator but I got stuck as samsum a-die is not availible.
So I got a few questions: should I go from overclocking?
Can you guys tell me a good start point? 3200 17-20-20-40 maybe?
Any tutorials maybe using asus mb as it will be easier to a noob to follow up ?
Thanks guys.
Rectangle Font Screenshot Parallel Number
This stuff basically doesn't OC at all and hates voltage.
If you wanted to OC with cheap DDR4, you should have gone for Kingston Renegade ram instead.
1 - 5 of 5 Posts
