Cheap Gaming Mouse
762 3
Hey,
I was thinking in buying CM spawn, but i dont want to spent more than 25/30 euros in a mouse. i prefer small mouses for claw grip and want a mouse with not much problems (accelaretion, prediction,...) and with a good sensor, i was thinking about a4tech x7 750bk, 755bk or even, 710 those have good sensor?
or someone knows one better?
1 - 4 of 4 Posts
You could get the cyborg v.3 mouse. I have the saitek gm2400 and it is shaped the same as this mouse and same buttons, but lower sensitivity. I really like the button software too. I would assume the software is the same because I saitek and cyborg used to be pretty much the same company. Only thing is that the buttons clicking are kind of loud for the gm2400.
EDIT: And unlike most gaming mice these have 3 buttons on the side which is the reason I got it. plus it is cheap.
EDIT 2: I did a google search and found that the gm2400 is about $15 and the v.3 is about $30
Do not buy a laser A4Tech mouse, check their site and choose only optical one: http://www.x7.cn/en/index.asp. All A4Tech have prediction, those with "3200 DPI" are equipped with ADNS-3080 and those with "2000 DPI" on the box have ADNS-3060 inside.
1 - 4 of 4 Posts
