1 - 11 of 11 Posts
Doesnt look like they have any pumps .....
I thought there was some kind of discount place or something i saw before that had cheap pumps but i cant find it
SNERP!!!
Try ebay. I got my Ehiem 1250 for $28 shipped.
What pump are you looking for?
Discussion Starter #9
Any opinions on the CSPMag from Dangerden? Is it a good pump? Im going to start with just a CPU water block but I might add a GPU block. What gph rateing is good for a GPU block and the Swiftech APOGEE water block and a tripple 120mm fan radiator?
SNERP!!!
Just about anything will work. It depends on what you want your temps to be. The Danger Den D5 is basically the best rounded pump out there. I love my Eheim it gives me great temps. So all pumps will work, it's just that some work better then others and you pay for the performance.
1 - 11 of 11 Posts
