Cheapest PSU that will run this rig?
311 Views 8 Replies 7 Participants Last post by  rfjunkie
X4 620
5770
1 HDD
770T motherboard
2 case fans
4 gigs (2x2) DDR3 RAM
I need like a 500w PSU, but shouldn't be too expensive. Max is 60 USD. Possible?
1 - 9 of 9 Posts
A Corsair 400 will run that no problems.
Here ya go.
It sounds like you already know what wattage you need? If you're not sure/want to double-check, use a psu calculator (google "psu calculator").
Heres a $20 500w psu: http://www.newegg.com/Product/Produc...82E16817193063
I would recommend spending more for a name-brand psu, but to each his own. Also, whats wrong with the antec in your sig?
Heres a $17 500w psu: http://www.newegg.com/Product/Produc...82E16817165024
Yeah, I would trust that psu...
Here ya go.
x3,great little psu I have one running my server.Or if you can possibly stretch the $$ a little this one is good also.
http://www.newegg.com/Product/Produc...82E16817139003
well i wouldn't either but the thread title did say cheapest psu so... I also updated my post because that one didn't have any pci-e connectors
I would go for the corsair 450 or the corsair 400 (only if you really care about the extra $10-$15 that the 450 would cost). Either would run your setup just fine. I would highly recommend against thinking of buying a cheap psu though. Remember, your entire system is dependent on it. Don't go anything lower than the two I suggested, and you'll be good to go
Not sure what that GPU requires for PCI connections but here is a 500watt one that I have and decent luck with running a single 9800GT Cooler Master 500Watt
1 - 9 of 9 Posts
