1 - 8 of 8 Posts
I was wondering how much a bottom of the line water cooling system would cost. Also, how much better than air cooling would it be.<br />
Thanks
Part 1: A good one will be over $100<br />
<br />
Part 2: Alot, but you get what you pay for
<tr>
<div>
Originally Posted by <strong>Mister Crowley</strong>
</div>
<div style="font-style:italic">Part 1: A <b>good? </b>one will be over $100<br />
<br />
Part 2: Alot, but you get what you pay for</div>
</td>
</tr>
</table>
</div>Bottom of the line means El Cheapo(i know over 100 is cheap but can you go cheaper?)
you can build a 3/8 for 60$ but it would be the same as a good air hs.<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835103006" target="_blank">like this one</a>
Look for some of Snerps posts here in the WC section, look in his sig for putting togather a cheap WC rig around $150.00 . Thats about as cheap as you can go and have something that will cool well and be upgradable..
yeah . .if you go below $100 then your probably getting the same performance as highend air for twice the cost . . . i could have probably gone air and had the same (if not better) results . . . but then it wouldn't look as good lol. . . <br />
<br />
(BTW my kit matched my case and it cost ~120)
well if you were good at working metal like my friend is you could make the cpu block and you can make your own reservoir so all you need is a pump, radiator, lines fluid and fans (probably around 60US) <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> thats what I plan to do <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
1 - 8 of 8 Posts
