Sup!
Been just over 2 years that my xfx 7970s arrived at my door and I was bursting with excitement at all the reviews, only to find that the damn things won't clock past 1050Mhz.
So having waited 2 years and the market hasn't really progressed, more just got more expensive (pointless upgrading till I can at least get a single card outdoing both for an acceptable price), leaving me with that "itch".
So alas, watercooling it is, my aim is 1200Mhz, but here's the thing, 1 rad, no cpu in the loop (h100i is doing just fine).
Case: Corsair 650D (for rig check sig)
(you'll notice a lot of alphacool, delivery costs direct from them etc etc)
Radiator: Alphacool Monsta 180mm (tis indeed a monsta)
Fans: push/pull Silverstone Air Penetrator AP-181 (don't like the white 182s)
Pump: Alphacool VPP655 - G1/4 IG incl. Attachment
Resevoir: Alphacool Repack Single Bay 5,25" - Rev. 2
Waterblocks: 2x Alphacool NexXxoS ATXP ATI 7970/50
Thermal Paste: Artic MX-4
Fittings: 8x Alphacool HF Screw connector G1/4 outer thread on 13/10 - Deep Black (4x normal/ 4x angled)
Tubing: Hose Masterkleer 13/10mm UV- reactive blue (3/8'ID)
Coolant: Koolance Liquid Coolant Bottle High-Performance UV Blue
Let me know what you think, particularly with regard to the 180mm Monsta handling 2x7970s all by itself, bare in mind this is an 85mm deep rad with overall volume similar to most dual 180mms.
Cheers
/Severe
Cheers
/Severe
