check my build
492 Views 10 Replies 9 Participants Last post by  guitarcrazy44
i finally finished my new build...i am still within the warranty/return timeline, so i can return parts if they absolutely suck. I just need to know if the parts meet the crysis/halo 2 par, nothing else, im not looking for the best of the best parts, just a system that will run crysis/halo 2 on full settings smootly...
CURRENT BUILD
CPU: THIS
PSU: THIS
GFX (gaming): THIS
GFX 2 (not sli, for dual monitor support): THIS
MOBO: THIS
DDR2: THIS X2
1 - 11 of 11 Posts
I think you should get a 640MB instead and drop the second card.
http://discuss.extremetech.com/forum...004379372.aspx
Agreed. Or if you can push yourself to a GTX, get that.
Here's a better motherboard for the same price. The ASUS P5NE-SLI, for 87$ OEM.
Socket 945 is not very well respected for overclocking. plus with this board you get tons of options, AND 1333 support, aswell as quad readiness and sli. what more can ya ask for?
I agree with Coma and Empty. It would be best to get the 640MB version or a GTX instead of a second card, even for dual display. you w ill get a lot more performance out of it.
That psu has to go
Originally Posted by sccr64472
That psu has to go
seconded!
That PSU gives me the willies. The rest seems ok, although even with one 8800 you will be able to do dual monitor.
Suggest getting a 640MB.
not sure about Crysis, but Halo 2 runs on High setting with 2xAA @ 1280x1024 (though a bit laggy) even on my Sempron Vista computer (in my sig)
agree with everyone else, the mobo and PSU seems a bit weak.
GTX is out of my budget..if it wasnt i would be all over that
yea i already knew my psu was done for with my build..i'm planning on getting a 700w psu from newegg, just not sure what one yet
1 - 11 of 11 Posts
